If your seeing 15 volts at the alternator stud or on the output wire and only 13.0 volts at the battery you have a bad connection( high resistance, corrosion or loose) somewhere between the two
Two volts drop between the two is way to much
take your volt meter and trace it back from the alternator to the bulkhead connector and then back on the other wire that feeds to the battery
If your seeing 14+ volts into the bulkhead connector and less than than 14.0 volts coming out your on the way to fixing it
I have seen more than one Mopar, 1966 to 1971 model yrs. have the inner nut on the amp gauge loose causing what you may have now
Please let us know what you find so others on here can benefit from your work also
What year, make and model car are you working on?
Hopefully someone on here will have the correct year and model factory service manual (FSM) so they can look up the wiring schematic and tell you which wire color and pin location to test from
