I bought one from Edlebrock years ago, call Summit and Jeg's and see if they stock them or not. scope
It should come with a adapter for smaller two barrel type carbs and for the early small AFB size air cleaner bases, You set one carb. at a time and set it up the way you want it and then make the other carb. match it wrench
