The rear carb is the primary carb by virtue of the choke.
And it’s not a coincidence the intake manifold has heat to the back/primary carb plus with the carbs off you will notice that the rear/primary part of the manifold has an interconnection slot cut in it - for driveablity fuel distribution at low speed.
