Originally Posted by BDW
Originally Posted by charger RTSE
[quote=bennoel]
Yes same thing to me with the Moog clunk noise braking when car would finish braking and move back, took me some time to work it out the metal piece in the bush was cracked.
I have a clunking noise I can’t pin down. Any more details on this?
I was referring to a-body strut rod bushings as they are a one piece bushing originally from the factory. I came to the conclusion that the two piece replacement bushing is too thick. I also believe as a result of the improper size it puts pressure on the LCA towards the rear. I don't think this can be good for the LCA bushings either because if I'm correct its as if the strut rod is now too long. Just my opinion. Hope this helps
