Will this be for drag only or for the street also.. the biggest issue is
getting the strut length you need if its going on the road
Drag only
I built my whole car.. it not that hard.. you just need to get your camber
and caster set right when your building the front end and get the
ride height where you want it.. set it up on paper first.. I made little
3D cut outs first so I could see the movement of the struts.. I went
with 10* caster so it would drive nice and straight.. was perfect for
my short wheel base
