Originally Posted by pittsburghracer
Originally Posted by DusterKid
When going with a strut front end is it possible to use the factory front frame rails (1975 duster)? I already have a snout bar going from my cage to the shock mount and tied to the front of the frame rail just trying to figure out how much I may have to undo to make this change.
Check out some of the heads up cars. Lots of classes require Stock front frames but allow A arms or struts
Thanks did not know that.
