Went through a few photos and realized there are fiber or felt like washers on the studs between the finish panel and the trunk lid like these.
Mine had the same washers. More like a flattened foam similar to some of the other body gaskets.
Thanks you're right they are foam like and you could probably make them from sheet foam that is used for most electronic packaging currently. If you've ever seen the foam that is used on or between the front brake backing plates and the spindles it's very similar or the same?
