Originally Posted by moparjoe360.4
Originally Posted by TonyS451
fwiw, back in the day on my 71 Demon I ran a 28.x11.5 hoosier quick time pro (10" tread width) on a 8" weld draglite w 4.5 backspace. Springs in stock location and they fit, but not a ton of room..
That gives me hope that I can make them fit. The 11.5 QTP lists as a 11.2 section width.
see what wheel the specs were based on. a slightly narrower wheel may pull the sidewall in a bit, allowing you to use that tire.
beer
