Closing off the upper grille should be worth a few MPH; the more flush, the better.
You'll have plenty of air for cooling coming in through the valance.
If you can do it, another hood with some venting to let trapped air escape will also help.
I'd also remove the side mirrors, and probably lower the nose a bit; 5-degrees down has been shown to have benefits.
