Check local shops. Im not in an overly big area yet we have at least two truck shops around that do that kind of work and probably not too hard to find more if someone was willing to drive an hour or two away.
EDIT:SInce you can't make yourself available when your local places are open see if they will deliver or if they will take instruction from you over the phone if you get someone to do the drop off/pickup.
