No mid plate. I couldn’t fi t one in there even if I wanted one. The stock firewall, stock frame rail, stock suspension mounting points make these cars very tight
Yes you can John as mine has one with a steel front and you have a removable glass front...We have no trouble installing engine & trans together,JMO !!
There’s that magic word again (WE). We is ME at my shop and working on the floor makes everything harder. There is absolutely zero room for a mid plate on this car. Heck my B1 head drain fitting is smack up against the firewall.
