I press the brake pretty hard and set the line lock. Dump the clutch at 5000, try to hold it at around 5500-6000. 4.57 rear, 1.78 2nd, 1.30 3rd,
Rear tires are MT ET Street, LT 30 x 13.5-15, Bias-Ply, front are 6.70-15 bias ply. Straight front axle, wilwood discs, 4 link rear, afco coil overs on all 4 corners.
So in 2nd gear 5500 rpm is 60 mph. 3rd gear at 6000 would be 90 mph
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
