More wheelspeed plain and simple..If it launches and drives straight after the launch then it clearly is not a brake, chassis or tire thing. Since you say its a burnout thing I assume only when which means you need more wheelspeed. HIgh gear and how much depends on the car but enough for it to go straight is the answer
