Originally Posted By bee1971
What’s the difference in material between the Fel Pro 50145 R that most local jobbers sell and stock , and the Fel Pro 1612 as both are some kind of fiber
I have used both on factory straight and clean valve covers , and I definitely can recommend the one I wouldn’t use again on a factory valve cover
383/440 Magnums
So would you share with us what gasket you would not use? Pretty please. shruggy
