Anyone using VS 50145 R Gaskets? I'm installing a set VS 50145 R on a 1969 Dodge 440 with stock valve covers. The Factory service manual reads 40 inch pounds of torque but the instructions that came with the gaskets reads 90 inch pounds of torque. Which torque spec should I use? Thank You
