If you are going to be cornering hard then you'll also need to baffle the valve covers so you aren't puking out of them and update the dipstick with a good seal. You'll also probably need to baffle the rear axle and/or move the vent up. Might need to so something with the gas tank too. Everything starts to leak when you corner hard and it sucks to get black flagged and put on the trailer after spending a bunch of time and money getting to the event.
