Under dash usually, and usually AutoMeter. Copper lines on the ones I've installed are still fine 30+ years later; as said, allow for flex. Only problem with braided stainless is it abrades whatever surfaces it rubs against unless covered with heat-shrink tubing. Otherwise excellent. Aesthetically I like to have an added gauge fit the theme & interior styling of the car.
