I've always used the nylon tubing and have never had a problem. The problem with copper is that over time it can crack due to vibration. That's why its not advisable to use copper for fuel lines like they used to do in the '50s on hot rods. If you follow the directions for the install the nylon tubing will work just fine.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
