This happens quite regularly on built street/strip cars, they get heavy quick! Cage, safety equipment, heavy block, better cooling system, heavy duty trans with an added cooler, shield and gear vendors unit. Fuel system is heavier than stock, electrical system is heavier than stock, it all adds up!
I forgot about the gear vendor, and trans cooler, electric fans, big fuel pump etc. it all adds up. I will start looking for places to remove weight, just started reading the thread on here lots of good info there.
