We have had ok luck with autozone remans. Dodge rwd trannys I re-build my own self and am shocked at what I see in the ones marked mopar reman. I commonly see the wrong planetariums and wrong number of clutches in those like the diesel ones getting lighter duty gas parts probably because they just had them sitting around in the factory, it is no wonder they got such a reputation as bad trannys, the re-mans dont last as long as the factory ones and the factory ones usually fail as a result of bad maintenance. The auto zone ones probably last longer as they put the right stuff in them because they dont just have stuff laying around.
