It cracked the wall vertically. On the non thrust side. the thing always ran warm. Non fill. I'm thinking it has some thin walls. -8 on the block. The machine shop I was using didn't sonic check it. The block I'm going to hopefully use after it gets checked for thickness is a -2. We'll see if it's any good. Thanks for the info fellas!
