just pulled the aluminum LPW cover off my d-60 to check things over and cannot remember how much oil I need to put back in ,this cover has no sight plug for the correct level just a drain plug and a fill plug up at the top, I have 2 1/2 quart in it so far, how much are you drag racers running in your's?
