I know a better gear would help, but I found a
great deal on the 3.23 and considering I drive
a lot on the freeway it seemed like a good
choice to go with. It had a 2.76 when I bought
it, talk about a clutch riding killer!
Using the plain steel spring in the secondary's
and the stock PV was 6.5 but changed it to 4.5.
Vac is around 9-10 but the cam has a long duro
and I was told from eddy this is common for
that grind so I do not think I have a leak
anywhere. I will check the shot size to see
what that is and I believe I have the white
cam on the acc pump.
