I wouldn't recommend using the JW Flexplate...Ive lost ring gear teeth on 2 of them.
I use a Meziere flex plate and Reid bell / trans case
I'm going on 30 years of Powerglide use in 4 different cars (big block and small block) and have never hurt a JW Flexplate. I am almost paranoid about starter installation and spend hours getting them shimmed right. Almost every combo I set up is shimmed differently some with the nose on but many I have cut the nose of the starter off. Shim kits come in VERY handy and are available at Summit.
Untitled by
John Cadamore, on Flickr
Untitled by
Untitled by
Untitled by
