Probably wont be able to use the Mopar ECU, On the Ram 5.7 some of the electrical connectors are in different spots, the Cam is different from the LX because of the active intake, after taling to chris at hot wire, he has a plug n play set up for use with the DBW TB
for the 58 tooth tone ring hemis
