Anyone with suggestions for the intake gaskets? I guess this is mainly an issue with the water passages. I used a high temp silicone before but applying that by dispensing from a tube was not real easy. Moving the tube at a consistent speed while you're trying to push the tube with a consistent force is not my strong suit.
- EM
