I have used them in boosted application. Zero problems with the crank. Calculated 1660hp. Thaxs this what I wanting to hear. Well then....I guess it's time to step up the fogger jets! Zero issues with my low deck 4.15" Molnar crank. Just a small shot of spray....for now. Same thoughts here. My biggest concern is the factory block now.
'63 Dodge 330 11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs. 10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
