So I wonder how fast would it be if you put a ECU on it that doesn't retard the timing by 6-8* under load? I will guess and say it would run 10.50's at least.
It's pretty common knowledge that the Orange box retards timing under load starting at 3000 RPM and by 5200 it's retarded by at least 8*.
Orange boxes haven't been made by Mopar for close to 20 years and they are all Chinese copies, less than $5 from China.
There's a reason they specify: "Mopar Performance parts beginning with a “P” prefix are sold “as is” unless otherwise noted. This means that parts sold by Mopar Performance carry no warranty whatsoever."
Summit-No Longer Available
Jegs- No Listing
Mancini- No listing
Ever wonder why?
