Originally Posted By Supercuda
How do you think the clutch is mounted vertically? It's CENTER LINE is horizontal not vertical
i most certainly agree with this, as is the center line of the crank shaft, alternator, water pump, and power steering pump. however, just like a flywheel and clutch/pressure assembly, the mounting position of these components are/is considered to be on the vertical plane. the center line of these components, however, is still in the HORIZONTAL plane, which is different than the mounting position.
beer
