My 2011 doesn't have a delay in gas pedal.
Now my 2014 T&C on the other hand- you dont want to pull out in front of somebody in that thing. Terrible lag. I can give the pedal a quick "blip" & the engine rpms wont even raise.
If I drive mine normally, as I do 99.9% of the time, you would never think that there was anything wrong. That .1% when I'm at a stop light and punch it from an idle is when there is a dead spot. If I load the converter a bit ( a few rpm above idle), the engine responds normally. I've lived with it for the past 7 years. Maybe I'll continue to just live with it??? I really don't want to spend money on something that I will use one time and not need anymore.. Thanks for all the replies..
