The plugs on the left look better.
The only way for anyone but you to see your WOT tune up is to take the shells off the plugs and post a picture of the porcelain.
For your WOT here should be a .060ish wide ring at the bottom of the porcelain and the rest of the porcelain should be clean. We can't see that with the shells on.
On pump gas, the timing line/mark on the ground strap should be just past the corner heading towards the shell.
So the timing mark on some of them looks close.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
