So who makes a repopped single piece rotor for 66-69 Bendix? I have only see the rotor that requires and original hub to mate too it.
https://www.carid.com/right-stuff-detail...&url=722009Look here.
I knew i had it filed somewhere in one of the computers that i use, but i didn't know which one, until i found it.
I think you need to look at that a little closer. Google will help. Fitment 68-74 charger; 70 to 74 E body. Clearly wrong. That is really a 70-72B and 70-74E rotor. That is the one that does not fit right when folks try to use it on a Bendix set up.
