What about a brake pedal switch or a parking brake pedal switch? I have had a vehicle where the switch was too sensitive and a bump in the road would kill the cruise. Had to adjust the switch out a bit, problem solved.
DT .. I did consider that but this situation kills the system temporally ... A brake lite deal would allow you to hit the resume button and be on your way.
