Yes - the shifter is horrible and the harness has been hacked up. Needs the bulkhead plugs in the firewall.
I think I have a factory 727 valve body which hopefully makes the shifter better.
It has solid engine mounts which makes no sense on a street car and edelbrock dual four intake. I'll probably put a single carb torker or performer intake. It needs to be daily driver friendly for the wifey.
I'm sure there is some bondo under the paint but I couldnt find any rust. Pretty sure its an enamel paint and not base clear so its was probably painted in the 90's.
