What tires do you have on the car? I'd think that big tires would be the most important modification but I don't see it listed. You might need to find a competitive tire and then work backwards from there. If you use 17 inch or larger then you can step up to some bigger brakes. Not sure if you really need big brakes for autocrossing but it is an option.
