One advantage of the shield has is that it only needs to be recertified every five years, the blankets are every two years.
If you get a blanket Stroud Safety well recertify theirs, not everyone will.
Stroud will custom make them also. As alluded to above if you are in the nines you will need a SFI flexplate and flexplate shield.
