Well approx. 6-7 years ago I was shopping carpets. At the time I went with MotorParts South. When I say the carpet fit perfectly I mean perfect. It fit every contour of the floor pan and absolutely great around the four speed hump. There was enough carpet to trim, it actually covered the sill plate area, went well up to and past the steering column and plenty under the rear seat. I’ve recommended this vendor in the past but without much support. I am soon going to need another and only hope they can supply the same product. I originally found them in Mopar Collector Guide.
