These are of the late piston locations in 1st (top pic) and 2nd (bottom pic); again, blue is line pressure the green striped fluid is from the 1-2 Shift Control Valve. The fluid pressure from the 1-2 Shift Control Valve offers a variable resistance to the piston's movement and, therefore, cushions the shift in proportion to the throttle opening.
