I have a '73 manual here with those charts. Of course it's all based on a stock trans. The accumulator basically acts as a cushion for the front servo to soften the 1-2 shift. On a stock unit the pressure controls in the valve body and the governor also influence that shift firmness.
If the results don't match the theory, change the theory.
