As far as I know ALL the cast crank engines were externally balanced. You will need a weighted torque converter for your application or you could get a B+M flexplate for that engine, then you could use any neutral balance torque converter. I have a cast crank 71 383 and used the B+M flexplate. I now have a neutral balanced high stall converter behind it. It's about $100 from Summit.
