Originally Posted By demon
Originally Posted By BigHemiVegas
Can a full one piece trunk floor be slid in from the side without removing the rear tail panel if both full quarter panels are removed on a 1968 Dodge Charger?
No, not unless you remove the inner wheelhouse on one side. This is the hard way to do it.
The trunk floor will slide in from the rear with ease on a Charger when the rear valance is removed, which almost always needs replacement too if doing quarters. The trunk floor welds to the rear valance on a Charger.
Done many
Hi Demon what is the procedure with a 70 Satellite. Do i remove the rear cross member as well as the rear valance
