Gasket pattern is stock, and for the most part, yes, stock valve covers will work. Depending on valve lift and rocker design, I would be checking clearances for rockers and shaft hold downs. How stock are you talking? OE valve covers or aftermarket replacements? I've had Milodon stamped aluminum valve covers that needed massaging fitting my shaft hold downs and Harland Sharps on 915 heads.
