Specifics would be helpful.
understood, 360 iron OE block/EQ iron heads. block milled flat/heads (new) checked flat 9-1 SCR (class rules) 2bbl. ~6200 RPM max circle track races of ~30 minutes duration in the features. I can't get quench (.111" down) but I wanna get close to the SCR limit & start useing some of my hoard of parts. EDIT I read the above posts & good point that 0 ringing (a shop quoted $150 aways back) would be more than some gaskets would be.
