Originally Posted By an8sec70cuda
Definitely need a fore-aft limiter of some sort.....
Make sure your frame brackets are located BEHIND the motorplate.
good advice!!!
I run the fore-aft limiter from the frame to the motor mount tabs on the block. there may be a better spot to mount it on the block or trans, but the options are limited with so little room.
Not sure which plate OP will be using, but another benefit to having the frame brackets behind the plate is that switching to a thicker plate won't push the motor back.
