Tends to flop around a little if you don't bolt it down with all three holes in the bracket....like this.I also flattened out the other small bracket and use that as a backing plate behind the aluminum motor plate.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
