i need help resolving a electrical issue that just happened. i saw that my idle solenoid wasnt popping up when the key was in the on position so i pulled the blue solenoid wire and it grounded up against up the barrel and lost power to the wire, the problem is now i go and try to stsrt the superbee and it fires immediately then cuts out.
i thought i might have fried the ballast resistor but i put a jumper wire on the ballast resistor and it does the same thing.
the only way for me to keep the car running is a wire from the positive side of vthe coil to the positive side of the battery then i pull the wire off the battery and it stalls.
Im lost. what id wrong?
i think something is either fried or shorted out? i shorted out the blue solenoid wire briefly 4 or 5 times trying to get the stud of the solonoid back into the barrel, it popped out. pleae help thanks
