Many leanburn vehicle did use dual pick-up dist as was said but not all of them did. Also your dist should not have any mech advance in it as I don't remember any leanburn dist's have mechanical or vacuum advance since the computer controlled the timing advance. If its a single pickup unit in theory you could lock the mech advance and not use the vacuum advance and make your dist work but if I were you I would just get the right one. Good luck , Ron
