I’m all for using the 184 pistons with reworked stock heads. But...... that’s quite a bit more involved of a project than bolting on a new set of heads.
And, unless the stock heads are in remarkably good condition....... you could easily spend almost as much(or more) prepping/refurbishing them than buying the budget friendly aftermarket alternatives.
Then, when it came time to tear into the shortblock you could just use flat top pistons instead.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
