Do you know what engine RPM you want to shift at and what the RPM is at the stripe?
Right now i shift at 7000 and cross about 6800. Somewhere close to that is kinda where i want to stay.
Thats with the convertor flashing at 6120 via the racepack.
The valve pockets are plenty deep.
The block is the older mopar mega block.
I make 350 passes or so a year so i do like something easy on the valve train.
I am still running the same the cam i had ground for my 528 years ago and then i switched to the 572 combos in 2011.
Just thought i would put the correct cam in it to make it a little more stout.
Want to be in the 4.70s in any weather instead of the 80s like it is now.
