I realize you already have the castings prepped, so those are what you’ll use...... but I would have preferred to use the 1.88 intake valve for that combo.
Actually, I would have probably used 1.94 sbc valves....... along with minimal bowl work and a tweak of the short turn.
I’d have shot for flow in the 220-225 range.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
